Displays the threshold table with the range of current-bandwidth and the corresponding absolute adjustment-threshold.
| URI | Description |
| <base_URI>/operational-state/mpls-state/autobw-threshold-table-entry | Displays the threshold table with the range of current-bandwidth and the corresponding absolute adjustment-threshold. |
| <base_URI>/operational-state/mpls-state/autobw-threshold-table-entry/{bandwidth}/threshold | Displays the absolute adjustment-threshold corresponding to the bandwidth. |
| <base_URI>/operational-state/mpls-state/autobw-threshold-table-entry/{bandwidth}/is-percentage-threshold | Displays whether percentage-based threshold method is used. Boolean value. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the threshold table parameters.
http://host:80/rest/operational-state/mpls-state/autobw-threshold-table-entry
None
<<autobw-threshold-table-entry xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state/mpls-state/autobw-threshold-table-entry/567"> <bandwidth>567</bandwidth> <threshold>800</threshold> <is-percentage-threshold>false</is-percentage-threshold> </autobw-threshold-table-entry> <autobw-threshold-table-entry xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state/mpls-state/autobw-threshold-table-entry/1000"> <bandwidth>1000</bandwidth> <threshold>500</threshold> <is-percentage-threshold>false</is-percentage-threshold> </autobw-threshold-table-entry> <autobw-threshold-table-entry xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state/mpls-state/autobw-threshold-table-entry/10000"> <bandwidth>10000</bandwidth> <threshold>3453</threshold> <is-percentage-threshold>false</is-percentage-threshold> </autobw-threshold-table-entry> <autobw-threshold-table-entry xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state/mpls-state/autobw-threshold-table-entry/2147483647"> <bandwidth>2147483647</bandwidth> <threshold>10</threshold> <is-percentage-threshold>true</is-percentage-threshold> </autobw-threshold-table-entry>
