aaa/authentication
Configures, retrieves, and modifies AAA login sequence.
Resource URIs
URI Description
<base_URI>/config/running/aaa/authentication Configures AAA login sequence.
GET URIs Description
<base_URI>/config/running/aaa/authentication/login Specifies the type of server that will be used for authentication, authorization, and accounting (AAA) on the device. The local server is the default.
<base_URI>/config/running/aaa/authentication/login/first Configures the primary source of authentication.
<base_URI>/config/running/aaa/authentication/login/second Configures the secondary source of authentication.
PATCH URIs Payload Description
<base_URI>/config/running/aaa/authentication/login <login><first>{enumeration}</first></login> Configures the order of sources for login and sets the primary source of authentication.
PUT URIs Payload Description
<base_URI>/config/running/aaa/authentication/login/first <first>{enumeration}</first> Configures the order of sources for login and sets the primary source of authentication.
<base_URI>/config/running/aaa/authentication/login/second <second>{enumeration}</second> Configures the order of sources for login and sets the secondary source of authentication.
DELETE URIs
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/aaa/authentication
None
<authentication xmlns="urn:brocade.com:mgmt:brocade-aaa"
xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/aaa/authentication">
  <login y:self="/rest/config/running/aaa/authentication/login">
    <first>radius</first>
    <second>local-auth-fallback</second>
  </login>
</authentication>
URI
The following example uses the PUT option to configure AAA login sequence.
http://host:80/rest/config/running/aaa/authentication/login/first
None
URI
The following example uses the DELETE option to remove AAA login sequence.
None
None
