interface/{interface-type}/{interface-name}/ip/policy
Configures, modifies, or retrieves the Policy-based Routing (PBR) configuration.
Resource URIs
URI Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/policy Configures PBR.
Supported interface types are: Ethernet and VE.
GET URIs Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/policy/route-map Enables PBR. Supported interface types are: Ethernet and VE.
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/policy/route-map/route-map-name Enables PBR. Supported interface types are: Ethernet and VE.
PATCH URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/policy/route-map <route-map><route-map-name>{common-def:name-string63}</route-map-name></route-map> Enables PBR on an Ethernet interface or VE.
PUT URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/policy/route-map/route-map-name <route-map-name>{common-def:name-string63}</route-map-name> Enables PBR on an Ethernet interface or VE.
DELETE URIs
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Ethernet/%221/1%22/ip/policy
None
<policy y:self="/rest/config/running/interface/ethernet/%22195/7%22/ip/policy">
  <route-map y:self="/rest/config/running/interface/ethernet/%22195/7%22/ip/policy/route-map">
    <route-map-name>map12</route-map-name>
  </route-map>
</policy>
URI
The following is an example of the PUT operation to configure a route map.
http://host:80/rest/config/running/interface/Ethernet/%221/1%22/ip/policy/route-map
<route-map>
</route-map>
None
URI
The following is an example of the DELETE operation to remove route map.
http://host:80/rest/config/running/interface/Ethernet/%221/1%22/ip/policy/route-map/map12
None
None
