REST API requires the following transport protocols.
The following is an HTTPS configuration on an SLX device.
on SLX: crypto key label mykey rsa modulus 2048 crypto ca trustpoint myca keypair mykey end crypto ca authenticate myca cert-type https directory /root/<directory>/certs file ca.cert.pem host <server ip> protocol SCP user root password pass crypto ca enroll myca cert-type https common extreme country US directory /root/<directory> host <server ip> locality SJ organization Extreme orgunit Eng protocol SCP state CA user root password pass On Linux CA: ============ cd <your directory> openssl ca -policy policy_anything -extensions server_cert -out slx mgmt ip.pem -config openssl.cnf -infiles <slx mgmt ip>.csr From the CA host, find out the certificate creation time. The time on the switch must be later than this time, or the installation will not work: date; openssl x509 -noout -text -in <slx mgmt ip>.pem | grep 'Not Before' On SLX: =========== To adjust the time on the switch, run the following command. You might need to adjust for the time zone: clock set yyyy-mm-ddThh:mm:ss crypto ca import myca certificate directory <your directory> host <server ip> protocol SCP user root file <slx mgmt ip>.pem password pass copy running-config startup-config show crypto key mypubkey show crypto ca trustpoint show crypto ca certificates show running-config crypto key show running-config crypto ca
