Displays ISIS interface information in brief mode
| URI | Description |
| <base_URI>/operational-state/isis-state/interface-brief | Displays ISIS interface information in brief mode. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief | Displays ISIS interface information for particular interface. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/circuit-type | Displays ISIS circuit type. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/is-circuit-passive | Displays true if ISIS passive is enabled on the specified interface . |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/circuit-mode | Displays ISIS circuit mode. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/circ-state | Displays Circuit state. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/mtu-size | Displays mtu size. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/circ-adj-up | Displays up no of isis adjacency up. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/circ-changes | Displays ISIS interface state change. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/adj-changes | adjacency state change. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/is-l1-dis | Displays true if DIS L1 is enabled on the specified interface. |
| <base_URI>/operational-state/isis-state/interface-brief/isis-intf-brief/val_intf-type_val/val_intf-number_val/is-l2-dis | Displays true if DIS L2 is enabled on the specified interface. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/isis-state/interface-brief
None
<interface-brief xmlns="urn:brocade.com:mgmt:brocade-isis-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/isis-state/interface-brief">
<isis-intf-brief y:self="/rest/operational-state/isis-state/interface-brief/isis-intf-brief/eth%2C%221/49%22">
<intf-type>eth</intf-type>
<intf-number>1/49</intf-number>
<circuit-type>is-circ-lan</circuit-type>
<is-circuit-passive>is-disabled</is-circuit-passive>
<circuit-mode>isis-level1-2</circuit-mode>
<circ-state>true</circ-state>
<mtu-size>1500</mtu-size>
<circ-adj-up>2</circ-adj-up>
<circ-changes>1</circ-changes>
<adj-changes>2</adj-changes>
<is-l1-dis>true</is-l1-dis>
<is-l2-dis>true</is-l2-dis>
</isis-intf-brief>
<isis-intf-brief y:self="/rest/operational-state/isis-state/interface-brief/isis-intf-brief/eth%2C%224/10%22">
<intf-number>4/10</intf-number>
<mtu-size>9000</mtu-size>
<circ-adj-up>0</circ-adj-up>
<adj-changes>0</adj-changes>
<is-l1-dis>false</is-l1-dis>
<is-l2-dis>false</is-l2-dis>
</isis-intf-brief>
<isis-intf-brief y:self="/rest/operational-state/isis-state/interface-brief/isis-intf-brief/ve%2C101">
<intf-type>ve</intf-type>
<intf-number>101</intf-number>
<circuit-type>is-circ-ptpt</circuit-type>
<circuit-mode>isis-level2</circuit-mode>
</isis-intf-brief>
<isis-intf-brief y:self="/rest/operational-state/isis-state/interface-brief/isis-intf-brief/loopback%2C4">
<intf-type>loopback</intf-type>
<intf-number>4</intf-number>
<is-circuit-passive>is-enabled</is-circuit-passive>
<mtu-size>0</mtu-size>
</isis-intf-brief>
</interface-brief>
