system-monitor/tm
Configures, modifies, or retrieves Transient Buffer Congestion Detection settings.
Resource URIs
GET URIs Description
<base_URI>/config/running/system-monitor/tm/discard-packet/threshold Traffic Manager discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/discard-packet/logging-interval Traffic Manager discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/discard-voq-packet/threshold Traffic Manager VOQ discarded packets
<base_URI>/config/running/system-monitor/tm/discard-voq-packet/logging-interval Traffic Manager VOQ discarded packets
<base_URI>/config/running/system-monitor/tm/delete-packet/threshold Traffic Manager VOQ deleted packet monitoring
<base_URI>/config/running/system-monitor/tm/delete-packet/logging-interval Traffic Manager VOQ deleted packet monitoring
PUT URIs Payload Description
<base_URI>/config/running/system-monitor/tm/discard-packet/threshold <threshold>{uint32}</threshold> Sets threshold for Traffic Manager discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/discard-packet/logging-interval <logging-interval>{uint16}</logging-interval> Sets logging interval for Traffic Manager discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/discard-voq-packet/threshold <threshold>{uint32}</threshold> Sets threshold for Traffic Manager VOQ discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/discard-voq-packet/logging-interval <logging-interval>{uint16}</logging-interval> Sets logging interval for Traffic Manager VOQ discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/delete-packet/threshold <threshold>{uint32}</threshold> Sets threshold for Traffic Manager deleted packet monitoring.
<base_URI>/config/running/system-monitor/tm/delete-packet/logging-interval <logging-interval>{uint16}</logging-interval> Sets logging interval for Traffic Manager deleted packet monitoring.
PATCH URIs Payload Description
<base_URI>/config/running/system-monitor/tm/discard-packet <discard-packet><threshold>{uint32}</threshold></discard-packet> Sets threshold for Traffic Manager discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/discard-packet <discard-packet><logging-interval>{uint16}</logging-interval></discard-packet> Sets logging interval for Traffic Manager discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/discard-voq-packet <discard-voq-packet><threshold>{uint32}</threshold></discard-voq-packet> Sets threshold for Traffic Manager VOQ discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/discard-voq-packet <discard-voq-packet><logging-interval>{uint16}</logging-interval></discard-voq-packet> Sets logging interval for Traffic Manager VOQ discard packet monitoring.
<base_URI>/config/running/system-monitor/tm/delete-packet <delete-packet><threshold>{uint32}</threshold></delete-packet> Sets threshold for Traffic Manager deleted packet monitoring.
<base_URI>/config/running/system-monitor/tm/delete-packet <delete-packet><logging-interval>{uint16}</logging-interval></delete-packet> Sets logging interval for Traffic Manager deleted packet monitoring.
DELETE URIs
Parameters
threshold
The threshold limit for discard packet count. Setting the threshold limit to '0' disables monitoring.
logging-interval
Specifies the set the time interval at which RASLOG is recorded if discard count threshold limit is reached. Default is 60 minutes. VOQ logging interval is adjusted to nearest multiple of 4.
Usage Guidelines
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/system-monitor/tm/discard-packet/threshold
None
<threshold xmlns="urn:brocade.com:mgmt:brocade-system-monitor" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/system-monitor/tm/discard-packet/threshold">14</threshold>
URI
The following example uses the PUT option .
<threshold>14</threshold>
None
URI
The following example uses the DELETE option .
None
None
