Configures MPLS RSVP.
| URI | Description |
| <BASE_URI>/config/running/router/mpls/rsvp | Enters MPLS RSVP configuration mode. |
Following are the supported URIs.
| GET URIs | Description |
| <BASE_URI>/config/running/router/mpls/rsvp | MPLS RSVP configuration. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-interval | RSVP Refresh interval. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-multiple | RSVP Refresh multiple. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-reduction/summary-refresh | Refresh Reduction Summary Refresh feature. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-reduction/bundle-message | Refresh Reduction bundle messaging feature. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-reduction/bundle-message/bundle-send-delay | Configures bundle send delay value. |
| <BASE_URI>/config/running/router/mpls/rsvp/reliable-messaging | RSVP Reliable messaging globally. |
| <BASE_URI>/config/running/router/mpls/rsvp/reliable-messaging/rapid-retrans-decay | Percentage increase in the rapid retransmission interval for each consecutive unacknowledged RSVP message. |
| <BASE_URI>/config/running/router/mpls/rsvp/reliable-messaging/rapid-retrans-interval | Interval for an unacknowledged message to be resent. |
| <BASE_URI>/config/running/router/mpls/rsvp/reliable-messaging/rapid-retry-limit | Maximum number of retries for an unacknowledged message. |
| <BASE_URI>/config/running/router/mpls/rsvp/hello | Enable RSVP Hello on all RSVP interfaces. |
| <BASE_URI>/config/running/router/mpls/rsvp/hello/interval | Interval between two RSVP Hello requests. |
| <BASE_URI>/config/running/router/mpls/rsvp/hello/tolerance | Number of unacknowledged RSVP Hello requests before timeout. |
| <BASE_URI>/config/running/router/mpls/rsvp/hello-acknowledgements | Acknowledge RSVP Hellos on interfaces supporting RSVP Hello and not having RSVP sessions. |
| <BASE_URI>/config/running/router/mpls/rsvp/backup-bw-guarantee | Setup a backup path requesting bandwidth only if bandwidth is available. |
| POST URIs | Payload | Description |
| <BASE_URI>/config/running/router/mpls | <rsvp /> | Enters MPLS RSVP configuration mode. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-reduction | <bundle-message /> | Refresh Reduction bundle messaging feature. |
| <BASE_URI>/config/running/router/mpls/rsvp | <reliable-messaging /> | Configure RSVP Reliable messaging globally. |
| <BASE_URI>/config/running/router/mpls/rsvp | <hello /> | Enable RSVP Hello on all RSVP interfaces. |
| PATCH URIs | Payload | Description |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-interval | <refresh-interval>{uint32}</refresh-interval> | RSVP Refresh interval. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-multiple | <refresh-multiple>{uint32}</refresh-multiple> | RSVP Refresh multiple. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-reduction/summary-refresh | <summary-refresh /> | Refresh Reduction Summary Refresh feature. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-reduction/bundle-message/bundle-send-delay | <bundle-send-delay>{uint32}</bundle-send-delay> | Configure bundle send delay value. |
| <BASE_URI>/config/running/router/mpls/rsvp/reliable-messaging/rapid-retrans-decay | <rapid-retrans-decay>{uint32}</rapid-retrans-decay> | Percentage increase in the rapid retransmission interval for each consecutive unacknowledged RSVP message. |
| <BASE_URI>/config/running/router/mpls/rsvp/reliable-messaging/rapid-retrans-interval | <rapid-retrans-interval>{uint32}</rapid-retrans-interval> | Interval for an unacknowledged message to be resent. |
| <BASE_URI>/config/running/router/mpls/rsvp/reliable-messaging/rapid-retry-limit | <rapid-retry-limit>{uint32}</rapid-retry-limit> | Maximum number of retries for an unacknowledged message. |
| <BASE_URI>/config/running/router/mpls/rsvp/hello/interval | <interval>{uint32}</interval> | Interval between two RSVP Hello requests. |
| <BASE_URI>/config/running/router/mpls/rsvp/hello/tolerance | <tolerance>{uint32}</tolerance> | Number of unacknowledged RSVP Hello requests before timeout. |
| <BASE_URI>/config/running/router/mpls/rsvp/hello-acknowledgements | <hello-acknowledgements /> | Acknowledge RSVP Hellos on interfaces supporting RSVP Hello and not having RSVP sessions. |
| <BASE_URI>/config/running/router/mpls/rsvp/backup-bw-guarantee | <backup-bw-guarantee /> | Setup a backup path requesting bandwidth only if bandwidth is available. |
| PUT URIs | Payload | Description |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-interval | <refresh-interval>{uint32}</refresh-interval> | Configure RSVP Refresh interval. |
| <BASE_URI>/config/running/router/mpls/rsvp/refresh-multiple | <refresh-multiple>{uint32}</refresh-multiple> | Configure RSVP Refresh multiple. |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option
http://host:80/rest/config/running/router/mpls/rsvp
None
<rsvp xmlns="urn:brocade.com:mgmt:brocade-mpls" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/mpls/rsvp"> <refresh-reduction y:self="/rest/config/running/router/mpls/rsvp/refresh-reduction"> </refresh-reduction> </rsvp>
The following example uses the POST option to configure MPLS RSVP.
http://host:80/rest/config/running/running/router/mpls
<rsvp/>
None
The following example uses the DELETE option to remove the MPLS RSVP configuration.
None
None
