Displays the bd-vc peer state.
| URI | Description |
| <base_URI>/operational-state/vc-peer-state | Displays the VC peer state. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
http://host:80/rest/operational-state/vc-peer-state
None
<data xmlns="http://brocade.com/ns/rest" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running">
<vc-peer-state xmlns="urn:brocade.com:mgmt:brocade-pwm-operational" y:self="/rest/operational-state/vc-peer-state">
<vc-peer-data y:self="/rest/operational-state/vc-peer-state/vc-peer-data/1">
<vc-id>1</vc-id>
<vc-peer-address>4.4.3.2</vc-peer-address>
<vc-peer-state y:self="/rest/operational-state/vc-peer-state/vc-peer-data/1/vc-peer-state">Operational</vc-peer-state>
<vc-peer-uptime>"22 hr 35 min 41 sec "</vc-peer-uptime>
<vc-peer-load-balance>true</vc-peer-load-balance>
<vc-peer-cos-enabled>false</vc-peer-cos-enabled>
<vc-peer-cos-value>0</vc-peer-cos-value>
<vc-ldp-tnnl-in-use>""</vc-ldp-tnnl-in-use>
<vc-local-label>983040</vc-local-label>
<vc-remote-label>983093</vc-remote-label>
<vc-local-mtu>1500</vc-local-mtu>
<vc-remote-mtu>1500</vc-remote-mtu>
<vc-local-type>4</vc-local-type>
<vc-remote-type>4</vc-remote-type>
<vc-proto-tnnl y:self="/rest/operational-state/vc-peer-state/vc-peer-data/1/vc-proto-tnnl/rsvp">
<vc-proto-name>rsvp</vc-proto-name>
<vc-ldp-tunnel-id>0</vc-ldp-tunnel-id>
<vc-ldp-name>""</vc-ldp-name>
<vc-lsp-name>tor4_1</vc-lsp-name>
<vc-peer-lsp-cos-enabled>false</vc-peer-lsp-cos-enabled>
<vc-peer-lsp-cos-value>0</vc-peer-lsp-cos-value>
</vc-proto-tnnl>
<vc-lsp-name>tor4_2</vc-lsp-name>
</vc-proto-tnnl>
</vc-assigned-lsp>
</vc-peer-data>
</vc-peer-state>
