mpls-state/te/router-id-map
Displays the MPLS TE database SRLG or CSPF group operational information.
Resource URIs
URI Description
<base_URI>/operational-state/mpls-state/te/router-id-map Displays the MPLS TE database SRLG or CSPF group operational information.
Usage Guidelines
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
URI
http://host:80/rest/operational-state/mpls-state/te/router-id-map
None
<router-id-map xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/mpls-state/te/router-id-map/1.2.3.4">
  <ip-address>1.2.3.4</ip-address>
  <router-id>1.2.3.4</router-id>
  <resolved>true</resolved>
  <igp-isis>false</igp-isis>
  <igp-ospf>true</igp-ospf>
  <isis-level>0</isis-level>
  <ospf-area>0.0.0.0</ospf-area>
  <origin-ted>true</origin-ted>
  <origin-path>0</origin-path>
  <origin-lsp>21052</origin-lsp>
  <origin-other>false</origin-other>
</router-id-map>
