Configures, retrieves and modifies an autobandwidth template.
URI | Description |
<base_URI>/config/running/router/mpls/autobw-template | Configures, retrieves and modifies an autobandwidth template. |
GET URIs | Description |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/adjustment-interval | Displays the time interval after which the LSP bandwidth should be adjusted. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/adjustment-threshold | Displays the adjustment threshold. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/min-bandwidth | Displays the minimum bandwiidth value in kbps. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/max-bandwidth | Displays the maximum bandwiidth value in kbps. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/overflow-limit | Displays the overflow limit. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/underflow-limit | Displays the underflow limit. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/mode | Displays mode value. Allowed values: monitor-only or monitor-and-signal |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/sample-recording | Displays whether sample recording is enabled or disabled. |
POST URIs | Payload | Description |
<base_URI>/config/running/router/mpls | <autobw-template><autobw-template-name>{string}</autobw-template-name></autobw-template> | Cpnfigures an Auto-bandwidth template |
PATCH URIs | Payload | Description |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name} | <autobw-template><adjustment-interval>{uint32}</adjustment-interval></autobw-template> | Configures the time interval after which the LSP bandwidth should be adjusted. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/adjustment-threshold | <adjustment-threshold><threshold-percentage>{uint32}</threshold-percentage></adjustment-threshold> | Configures the adjustment threshold. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/adjustment-threshold | <adjustment-threshold><use-threshold-table>true</use-threshold-table></adjustment-threshold> | Sets the status of use-threshold-table to true. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name} | <autobw-template><min-bandwidth>{uint32}</min-bandwidth></autobw-template> | Configures the minimum bandwiidth value in kbps. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name} | <autobw-template><max-bandwidth>{uint32}</max-bandwidth></autobw-template> | Configures the maximum bandwiidth value in kbps. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name} | <autobw-template><overflow-limit>{uint32}</overflow-limit></autobw-template> | Sets the overflow limit. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name} | <autobw-template><underflow-limit>{uint32}</underflow-limit></autobw-template> | Sets the underflow limit. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name} | <autobw-template><mode>{autobw-mode}</mode></autobw-template> | Sets mode value. Allowed values: monitor-only or monitor-and-signal |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name} | <autobw-template><sample-recording>{enable-disable}</sample-recording></autobw-template> | Enables or disables sample recording. |
PUT URIs | Payload | Description |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/adjustment-interval | <adjustment-interval>{uint32}</adjustment-interval> | Configures the time interval after which the LSP bandwidth should be adjusted. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/adjustment-threshold/threshold-percentage | <threshold-percentage>{uint32}</threshold-percentage> | Configures the adjustment threshold. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/adjustment-threshold/use-threshold-table | <use-threshold-table>true</use-threshold-table> | Sets the status of use-threshold-table to true. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/max-bandwidth | <max-bandwidth>{uint32}</max-bandwidth> | Configures the maximum bandwiidth value in kbps. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/min-bandwidth | <min-bandwidth>{uint32}</min-bandwidth> | Configures the minimum bandwiidth value in kbps. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/mode | <mode>{autobw-mode}</mode> | Sets mode value. Allowed values: monitor-only or monitor-and-signal . |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/overflow-limit | <overflow-limit>{uint32}</overflow-limit> | Sets the overflow limit. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/sample-recording | <sample-recording>{enable-disable}</sample-recording> | Enables or disables sample recording. |
<base_URI>/config/running/router/mpls/autobw-template/{autobw-template-name}/underflow-limit | <underflow-limit>{uint32}</underflow-limit> | Sets the underflow limit. |
DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to display the details of auto-bandwidth template "aaa".
http://host:80/rest/config/running/router/mpls/autobw-template/aaa
None
<autobw-template xmlns="urn:brocade.com:mgmt:brocade-mpls" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/router/mpls/autobw-template/aaa"> <autobw-template-name>aaa</autobw-template-name> <adjustment-interval>1800</adjustment-interval> <adjustment-threshold y:self="/rest/config/running/router/mpls/autobw-template/aaa/adjustment-threshold"> </adjustment-threshold> <min-bandwidth>5000</min-bandwidth> </autobw-template>
The following example uses the POST option to create an auto-bandwidth template called "aaa".
<autobw-template><autobw-template-name>aaa</autobw-template-name></autobw-template>
None
The following example uses the DELETE option to remove auto-bandwidth template "aaa".
None
None
