Displays IS-IS neighbor information
URI | Description |
<base_URI>/operational-state/adj-neighbor-entries-state | Displays IS-IS neighbors adjacencies. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor | Displays IS-IS specific neighbor adjacencies. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-state-change-time | Displays Adjacency State Change Time in Seconds. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-type | Displays Type of ISIS Adjacency. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-state | Displays Adjacency State. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/circuit-intf-name | Displays Circuit Interface Name. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/snpa | Displays Subnetwork Point of Attachment. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-holding-time | Displays Adjacency Holding Time. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-priority | Displays Adjacency Priority. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-3way-state | Displays Adjacency 3 Way Hand-Shaking State. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/host-name | Displays Host Name. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-lan-name | Displays Adjacency LAN Name. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-lan-id | Displays Adjacency LAN ID. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-p2p-circ-id | Displays Adjacency Point-to-Point Circuit ID. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-num-adds | Displays number of NSAPS/Areas Associated to the Adjacency. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-use | Displays Adjacency level Usage. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/ip-circuit-id | Displays ISIS IP Circuit ID. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-address | Displays IPv4 Circuit Address. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/ip6-circuit-id | Displays ISIS IPv6 Circuit ID. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-ip6-address | Displays IPv6 Circuit Address. |
<base_URI>/operational-state/adj-neighbor-entries-state/adj-neighbor/val_neighbor-id_val/adj-area | Displays Adjacency Area. |
Only GET operation is supported.
Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/adj-neighbor-entries-state
None
<adj-neighbor-entries-state xmlns="urn:brocade.com:mgmt:brocade-isis-operational" y:self="/rest/operational-state/adj-neighbor-entries-state"> <adj-neighbor y:self="/rest/operational-state/adj-neighbor-entries-state/adj-neighbor/IXIA1101"> <neighbor-id>IXIA1101</neighbor-id> <adj-state-change-time>494</adj-state-change-time> <adj-type>is-adj-l2</adj-type> <adj-state>UP</adj-state> <circuit-intf-name>Eth 1/49</circuit-intf-name> <snpa>0000.65dd.c2f7</snpa> <adj-holding-time>30</adj-holding-time> <adj-priority>0</adj-priority> <adj-mtprot>adj-mtprot-unknow</adj-mtprot> <adj-prot>enum=11</adj-prot> <adj-3way-state>adj-3way-state-up</adj-3way-state> <adj-lan-name>Fusion1</adj-lan-name> <adj-lan-id>3</adj-lan-id> <adj-num-adds>6</adj-num-adds> <adj-use>level-1-2</adj-use> <ip-circuit-id>3</ip-circuit-id> <adj-address>140.140.140.2</adj-address> <ip6-circuit-id>3</ip6-circuit-id> <adj-ip6-address>fe80::200:65ff:fedd:c2f7</adj-ip6-address> <adj-area y:self="/rest/operational-state/adj-neighbor-entries-state/adj-neighbor/IXIA1101/adj-area/49.0001"> <adj-asi-area-name>49.0001</adj-asi-area-name> </adj-area> <adj-area y:self="/rest/operational-state/adj-neighbor-entries-state/adj-neighbor/IXIA1101/adj-area/01"> <adj-asi-area-name>01</adj-asi-area-name> </adj-area> </adj-neighbor> <adj-neighbor y:self="/rest/operational-state/adj-neighbor-entries-state/adj-neighbor/IXIA1101"> <neighbor-id>IXIA1101</neighbor-id> <adj-state-change-time>496</adj-state-change-time> <adj-type>is-adj-l1</adj-type> <adj-state>UP</adj-state> <circuit-intf-name>Eth 1/49</circuit-intf-name> <snpa>0000.65dd.c2f7</snpa> <adj-holding-time>30</adj-holding-time> <adj-priority>0</adj-priority> <adj-mtprot>adj-mtprot-unknow</adj-mtprot> <adj-prot>enum=11</adj-prot> <adj-3way-state>adj-3way-state-up</adj-3way-state> <adj-lan-name>Fusion1</adj-lan-name> <adj-lan-id>3</adj-lan-id> <adj-num-adds>6</adj-num-adds> <adj-use>level-1-2</adj-use> <ip-circuit-id>3</ip-circuit-id> <adj-address>140.140.140.2</adj-address> <ip6-circuit-id>3</ip6-circuit-id> <adj-ip6-address>fe80::200:65ff:fedd:c2f7</adj-ip6-address> </adj-neighbor> </adj-neighbor-entries-state>
