Displays MPLS dynamic bypass configuration.
| URI | Description |
| <base_URI>/operational-state/mpls-state/dynamic-bypass | Displays MPLS dynamic bypass configuration. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-global | Displays global MPLS dynamic bypass configuration. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-global/config-enable | Displays whether dynamic bypass is enabled globally. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-global/config-enable-all | Displays whether dynamic bypass is enabled on all MPLS interfaces. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-global/reoptimize-timer | Displays status of reoptimization timer for dynamic bypasses. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-global/max-bypasses-per-mp | Displays maximum number of dynamic bypass LSPs that can be created per Merge Point. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-global/max-bypasses | Displays maximum number of dynamic bypass LSPs that can be created in the system. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-global/bypass-count | Displays dynamic bypass count. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface | Displays details of dynamic bypass on MPLS interface. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/active-status | Displays active status: Enabled indicates that net effect of global and local configuration enable leads to status is UP. Disabled indicates either local or global admin is DOWN. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/admin-type | Displays whether dynamic bypass configuration on the interface is because of local (interface) or global (MPLS device) mode configuration. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/admin-status | Displays when the dynamic bypass is enabled on the interface. UP indicates interface dynamic bypass is admin-config enabled, DOWN implies admin-config disabled. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/hop-limit | Displays hop limit. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/tie-breaking | Displays tie breaking mode for multiple equal cost paths. Allowed values are: random, least-fill, most-fill. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/cos | Displays CoS value. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/cspf-comp-mode | Displays bypass CSPF computation mode. Values are use-te-metric or use-igp-metric. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/setup-priority | Displays setup priority. Range is 0-7. 0 represents the highest priority. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/hold-priority | Displays hold priority. Range is 0-7 |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/traffic-eng-max-rate | Displays traffic maximum rate. Range is 0-2147483647 kbps. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/traffic-eng-mean-rate | Displays traffic mean rate. Range is 0-2147483647 kbps. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/traffic-eng-max-burst | Displays traffic maximum burst rate. Range is 0-2147483647 kbps. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/from-addr | Displays IPv4 from-address. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/reoptimize-timer | Displays reoptimization timer value for the Adaptive Bypass LSP reoptimization. Range: 300 to 65535 seconds. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/adaptive | Displays whether the dynamic bypass LSPs are adaptive or non-adaptive. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/record-route | Displays whether the setting to record route is enabled or disabled. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/name-prefix | Displays name prefix for the dynamic bypass LSPs. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/primary-path | Displays the configured explicit path for the dynamic bypass LSPs that are created for a protected interface. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/max-bypasses-per-mp | Displays the limit for total number of dynamic bypass LSPs that can be created to a merge point. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/bypass-count | Displays dynamic bypass count fpr an interface, |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/exclude-any | Displays number of admin-group configured as exclude-any. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/include-all | Displays number of admin-group configured as include-all. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/include-any | Displays number of admin-group configured as include-any. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/status-flags | Displays status flag number. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/mp-count | Displays number of merge points. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/mp-infos | Displays router ID address and bypass count for merge points. |
| <base_URI>/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/<if-index>/mp-infos/{router-id}/bypass-count | Displays bypass count per router ID address for a merge point. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/mpls-state/dynamic-bypass
None
<dynamic-bypass xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/mpls-state/dynamic-bypass">
<dynamic-bypass-global y:self="/rest/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-global">
<config-enable>2</config-enable>
<config-enable-all>0</config-enable-all>
<reoptimize-timer>0</reoptimize-timer>
<max-bypasses-per-mp>250</max-bypasses-per-mp>
<max-bypasses>250</max-bypasses>
<bypass-count>1</bypass-count>
</dynamic-bypass-global>
<dynamic-bypass-interface y:self="/rest/operational-state/mpls-state/dynamic-bypass/dynamic-bypass-interface/%22Eth
1/18%22%2Cethernet-interface">
<if-name>Eth 1/18</if-name>
<if-type>ethernet-interface</if-type>
</dynamic-bypass-interface>
</dynamic-bypass>
