Configures a VLAN.
URI | Description |
<base_URI>/config/running/vlan | Configures a VLAN. |
GET URIs | Description |
<base_URI>/config/running/vlan/{vlan-num}/ip/pim | Configures IP PIM on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/pim/snooping | Configures IP PIM snooping on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/pim/snooping/enable | Enables IP PIM snooping on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp | Configures IGMP. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping | Configures IGMP snooping on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/version | Enables IGMP snooping on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/last-member-query-interval | Configures the IGMP snooping last-member query interval. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/query-interval | Configures the IGMP snooping query interval. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/query-max-response-time | Configures the maximum response time for IGMP snooping queries. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/enable | Enables IGMP snooping on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/fast-leave | Enables IGMP snooping fast-leave processing for a VLAN. This allows the removal of an interface from the forwarding table without sending out group-specific queries to the interface. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/querier | Configures the IGMP snooping querier on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/querier/enable | Activates the IGMP snooping querier on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/mrouter | Configures a VLAN port member to be a multicast router interface. |
POST URIs | Payload | Description |
<base_URI>/config/running/ | <vlan><name>{uint32}</name></vlan> | Creates a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/mrouter | <interface><igmps-if-type>ethernet</igmps-if-type><value>{string}</value></interface> | Configures a VLAN port member to be a multicast router interface. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping | <static-group><mcast-address>{inet:ipv4-address}</mcast-address><interface>{enumeration}</interface><igmps-if-type>{enumeration}</igmps-if-type><value>{string-type}</value></static-group> | Configures an interface in a VLAN as a static member of a multicast group. |
PUT URIs | Payload | Description |
<base_URI>/config/running/vlan/{vlan-num}/router-interface/Ve | <Ve>{uint32}</Ve> | Ceates a router VLAN interface. |
<base_URI>/config/running/vlan/{vlan-num}/statistics | <statistics>(enum)</statistics> | Enables statistics. |
<base_URI>/config/running/vlan/{vlan-num}/desription | <description>(string)</description> | Adds the VLAN description. |
<base_URI>/config/running/vlan/{vlan-num}/ip/pim/snooping/enable | <enable>{enumeration}</enable> | Enables IP PIM snooping. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/version | <version>{unit32}</version> | Configures the IGMP snooping version. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/last-member-query-interval | <last-member-query-interval>{unit32}</last-member-query-interval> | Configures the IGMP snooping last-member query interval. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/query-interval | <query-interval>{unit32}</query-interval> | Configures the IGMP snooping query interval. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/query-max-response-time | <query-max-response-time>{unit32}</query-max-response-time> | Configures the maximum response time for IGMP snooping queries. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/enable | <enable>{enumeration}</enable> | Enables IGMP snooping on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/fast-leave | <fast-leave>{enumeration}</fast-leave> | Enables IGMP snooping fast-leave processing for a VLAN. This allows the removal of an interface from the forwarding table without sending out group-specific queries to the interface. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/querier/enable | <enable>{enumeration}</enable> | Configures the IGMP snooping querier on a VLAN. |
PATCH URIs | Payload | Description |
<base_URI>/config/running/vlan/{vlan-num}/ip/pim/snooping | <snooping><enable>{enumeration}</enable></snooping> | Creates a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping | <snooping><version>{unit32}</version></snooping> | Configures the IGMP snooping version. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping | <snooping><last-member-query-interval>{unit32}</last-member-query-nterval></snooping> | Configures the IGMP snooping last-member query interval. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping | <snooping><query-interval>{unit32}</query-interval></snooping> | Configures the IGMP snooping query interval. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping | <snooping><query-max-response-time>{unit32}</query-max-response-time></snooping> | Configures the maximum response time for IGMP snooping queries. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping | <snooping><enable>{enumeration}</enable></snooping> | Enables IGMP snooping on a VLAN. |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping | <snooping><fast-leave>{enumeration}</fast-leave></snooping> | Enables IGMP snooping fast-leave processing for a VLAN. This allows the removal of an interface from the forwarding table without sending out group-specific queries to the interface. |
DELETE URIs |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/mrouter/interface/{igmps-interface-type},{interface-name} |
<base_URI>/config/running/vlan/{vlan-num}/ip/igmp/snooping/static-group/{igmpl3-sg-addr}/interface/{igmps-interface-type},{interface-name} |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/vlan/11/ip/igmp
None
<igmp xmlns="urn:brocade.com:mgmt:brocade-igmp-snooping" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/vlan/11/ip/igmp"> <snooping y:self="/rest/config/running/vlan/11/ip/igmp/snooping"> <version>3</version> <querier y:self="/rest/config/running/vlan/11/ip/igmp/snooping/querier"> </querier> <mrouter y:self="/rest/config/running/vlan/11/ip/igmp/snooping/mrouter"> </mrouter> </snooping> </igmp>
The following is an example of the POST operation to configure a VLAN port member to be a multicast router interface.
http://host:80/rest/config/running/vlan/11/ip/igmp/snooping/mrouter
<interface><igmps-if-type>ethernet</igmps-if-type><value>3/12</value></interface>"
None
The following is an example of the DELETE operation to remove IGMP snooping last-member query interval.
http://host:80/rest/config/running/vlan/{vlan-num}/ip/igmp/snooping/last-member-query-interval
None
None
