interface/{interface-type}/{interface-name}/link-error-disable
Configures port link dampening {PLD}.
Resource URIs
URI Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/link-error-disable Configures port link dampening {PLD}. Valid interface type: Ethernet.
GET URI Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/link-error-disable/wait-time-in-sec Configures port link dampening {PLD} wait time. Valid interface type: Ethernet.
PATCH URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/link-error-disable <link-error-disable><link-error-disable-entry>1}</link-error-disable-entry><sampling-time-in-sec>{unit32}</sampling-time-in-sec><wait-time-in-sec>{unit32}</wait-time-in-sec></link-error-disable> Edits port link dampening configuration. Valid interface type: Ethernet.
PUT URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/link-error-disable <link-error-disable><link-error-disable-entry>1}</link-error-disable-entry><sampling-time-in-sec>{unit32}</sampling-time-in-sec><wait-time-in-sec>{unit32}</wait-time-in-sec></link-error-disable> Updates port link dampening configuration. Valid interface type: Ethernet.
Parameters
interface-type
Valid interface type:Ethernet only.
Specifies the link error disable entry.
Specifies the sampling time.
wait-time-in-sec
Specifies the wait time.
Usage Guidelines
GET, PUT, PATCH, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/ethernet/%221/1%22/link-error-disable
None
<link-error-disable xmlns="urn:brocade.com:mgmt:brocade-pld" xmlns:y="http://brocade.com/ns/
rest" y:self="/rest/config/running/interface/Ethernet/%221/1%22/link-error-disable">
  <link-error-disable-entry>1</link-error-disable-entry>
  <sampling-time-in-sec>10</sampling-time-in-sec>
  <wait-time-in-sec>10</wait-time-in-sec>
URI
The following example uses the PATCH option to update the configuration.
None
