Retrieves LDP information.
| URI | Description |
| <base_URI>/operational-state/mpls-state/ldp | Retrieves LDP information. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
https://host:80/rest/operational-state/mpls-state/ldp
None
<ldp xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/mpls-state/ldp">
<ldp-out y:self="/rest/operational-state/mpls-state/ldp/ldp-out">
<ldp-initialized>true</ldp-initialized>
<lsr-id>1.2.3.4</lsr-id>
<lsr-id-configured>false</lsr-id-configured>
<loopback>1</loopback>
<hello-interval-link>5</hello-interval-link>
<hello-interval-target>15</hello-interval-target>
<hold-time-sent-link>15</hold-time-sent-link>
<hold-time-sent-target>45</hold-time-sent-target>
<ka-interval>6</ka-interval>
<ka-multiple>6</ka-multiple>
<ka-timeout>36</ka-timeout>
<ka-timeout-default>true</ka-timeout-default>
<load-sharing>3</load-sharing>
<advertise-fecs-for-prefix-list>ldp-route-injection</advertise-fecs-for-prefix-list>
<advertise-fecs-for-prefix-list-exists>true</advertise-fecs-for-prefix-list-exists>
<inbound-fecs-filtering-prefix-list>""</inbound-fecs-filtering-prefix-list>
<inbound-fecs-filtering-prefix-list-exists>false</inbound-fecs-filtering-prefix-list-exists>
<outbound-fecs-filtering-prefix-list>""</outbound-fecs-filtering-prefix-list>
<outbound-fecs-filtering-prefix-list-exists>false</outbound-fecs-filtering-prefix-list-exists>
<tunnel-metric>0</tunnel-metric>
<fec-128-used-for-auto-disc-current>false</fec-128-used-for-auto-disc-current>
<fec-128-used-for-auto-disc-configured>false</fec-128-used-for-auto-disc-configured>
<end-of-lib>false</end-of-lib>
<eol-notification-time>60000</eol-notification-time>
<tx-silence-time>1000</tx-silence-time>
<rx-silence-time>1000</rx-silence-time>
<gr-enable>false</gr-enable>
<gr-helper>false</gr-helper>
<gr-reconnect-time>0</gr-reconnect-time>
<gr-max-peer-reconnect-time>0</gr-max-peer-reconnect-time>
<gr-recovery-time>0</gr-recovery-time>
<gr-max-peer-recovery-time>0</gr-max-peer-recovery-time>
<forwarding-state-timer-running>false</forwarding-state-timer-running>
<forwarding-state-timer-remaining>0</forwarding-state-timer-remaining>
<lwd-delay>60</lwd-delay>
<lwd-default>true</lwd-default>
</ldp-out>
</ldp>
