delete configuration
Deletes the prefix-independent-convergence configuration.
Resource URIs
URI Description
<base_URI>/config/running/cluster/no prefix-independent-convergence
Deletes the prefix-independent-convergence.
Parameters
Deletes prefix-independent-convergence.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/cluster/prefix-independent-convergence
None
http://<srvrip>:80/rest/config/running/prefix-independent-convergence
