Retrieves the time stamp of the last configuration change for xpaths.
| URI | Description |
| <base_URI>/operations/get-last-config-update-time-for-xpaths | Retrieves the time stamp of the last configuration change for xpaths. |
Only POST operation is supported.
http://host:80/rest/operations/get-last-config-update-time-for-xpaths
<get-last-config-update-time-for-xpaths></get-last-config-update-time-for-xpaths>
<output xmlns='urn:brocade.com:mgmt:brocade-vcs'>
<last-config-update-time-for-xpaths>
<xpath-string>/</xpath-string>
<last-config-update-time>1402481614</last-config-update-time>
</last-config-update-time-for-xpaths>
<xpath-string>/cee-map</xpath-string>
<last-config-update-time>1401508522</last-config-update-time>
</output>
