Configures and retrieves optimized replication under an overlay gateway instance.
| URI | Description |
<base_URI>/config/running/overlay-gateway/<gateway name>/optimized-replication |
Configures optimized replication under an overlay gateway instance. |
| GET URI | Description |
| <base_URI>/config/running/overlay-gateway/<gateway name>/optimized-replication | Retrieves optimized replication-related configuration information. |
| POST URI | Payload | Description |
<base_URI>/config/running/overlay-gateway/<gateway name> |
<optimized-replication> </optimized-replication> |
| <base_URI>/config/running/overlay-gateway/<gateway name>/optimized-replication | <underlay-mdt-default-group>{x.x.x.x}</underlay-mdt-default-group> |
Configures the default underlay MDT group for the specified IP address. |
| PATCH URI | Payload | Description |
<base_URI>/config/running/overlay-gateway/<gateway name>/optimized-replication/underlay-mdt-group |
<underlay-mdt-group><group-ip-address>{x.x.x.x}</group-ip-address><broadcast-domain-type>vlan</broadcast-domain-type><add>{16-20}</add></underlay-mdt-group> |
Configures the underlay MDT group for the specified IP address |
| DELETE URI |
<base_URI>/config/running/overlay-gateway/<gateway name>/optimized-replication/underlay-mdt-default-group |
<base_URI>/config/running/overlay-gateway/<gateway name>/optimized-replication/underlay-mdt-group/{x.x.x.x}vlan |
GET, POST, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
<optimized-replication xmlns="urn:brocade.com:mgmt:brocade-tunnels"
xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/overlay-gateway/g1/optimized-replication">
<underlay-mdt-default-group>239.0.0.255</underlay-mdt-default-group>
<underlay-mdt-group y:self="/rest/config/running/overlay-gateway/g1/optimized-replication/
underlay-mdt-group/239.0.0.1%2Cvlan">
<group-ip-address>239.0.0.1</group-ip-address>
<add>16-20</add>
