interface/Port-channel
Configures Port-channel interface.
Resource URIs
URI Description
<base_URI>/config/running/interface/Port-channel/{name} Configures the list of port-channels.
GET URIs Description
<base_URI>/config/running/interface/Port-channel/{name} Retrieves the pot channel.
<base_URI>/config/running/interface/Port-channel/{name}/speed Retrieves speed of the port.
<base_URI>/config/running/interface/Port-channel/{name}/description Retrieves interface specific description.
<base_URI>/config/running/interface/Port-channel/{name}/shutdown Shutdown the selected interface
<base_URI>/config/running/interface/Port-channel/{name}/minimum-links Minimum number of links.
<base_URI>/config/running/interface/Port-channel/{name}/mtu Sets mtu value to interface.
<base_URI>/config/running/interface/Port-channel/{name}/load-balance-type Hash based load balancing
PUT URIs Payload Description
<base_URI>/config/running/interface/Port-channel/{name}/speed <speed>1000</speed> Configures speed of the port.
<base_URI>/config/running/interface/Port-channel/{name}/description <description>R1toR2</description> Configures interface specific description.
<base_URI>/config/running/interface/Port-channel/{name}/shutdown <shutdown>true</shutdown> Configures the selected interface
<base_URI>/config/running/interface/Port-channel/{name}/minimum-links <minimum-links>2</minimum-links> Configures minimum number of links.
<base_URI>/config/running/interface/Port-channel/{name}/mtu <mtu>5000</mtu> Sets mtu value to interface.
PATCH URIs Payload Description
<base_URI>/config/running/interface/Port-channel/{name} <Port-channel><speed>1000</speed></Port-channel> Configures speed of the port.
DELETE URIs
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Port-channel/101/speed
None
<speed xmlns="urn:brocade.com:mgmt:brocade-interface" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/interface/Port-channel/101/speed">1000</speed>
URI
The following is an example of the PUT operation to configure interface specific description.
http://host:80/rest/config/running/interface/Port-channel/101/description
None
URI
The following is an example of the DELETE operation to remove a port channel.
None
None
