acl-policy
Configures, modifies, or retrieves ACL configuration.
Resource URIs
URI Description
<base_URI>/config/running/acl-policy Configures ACL policy.
GET URIs Description
<base_URI>/config/running/acl-policy/allow-conflicting-rules Allows conflicting rules in a ACL table.
<base_URI>/config/running/acl-policy/allow-duplicate-rules Allows duplicate rules in a ACL table.
POST URIs Payload Description
<base_URI>/config/running <acl-policy>()</acl-policy>
<base_URI>/config/running/acl-policy/allow-conflicting-rules <allow-conflicting-rules>true</allow-conflicting-rules> Allows conflicting rules in a ACL table.
<base_URI>/config/running/acl-policy/allow-duplicate-rules <allow-duplicate-rules>true<allow-duplicate-rules> Allows duplicate rules in a ACL table.
PATCH URIs Payload Description
<base_URI>/config/running/acl-policy/allow-conflicting-rules <allow-conflicting-rules /> Allows conflicting rules in a ACL table.
<base_URI>/config/running/acl-policy/allow-duplicate-rules <allow-duplicate-rules /> Allows duplicate rules in a ACL table.
PUT URIs Payload Description
DELETE URIs
Parameters
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to display whether duplicate rules are allowed.
http://host:80/rest/config/running/acl-policy/allow-conflicting-rules
None
<allow-conflicting-rules xmlns="urn:brocade.com:mgmt:brocade-acl-policy"
xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/acl-policy/allow-conflicting-rules">true
URI
The following is an example PATCH operation to allow duplicate rules in a ACL table.
None
URI
The following is an example of the DELETE operation to remove the ACL policy.
None
None
