Displays IGMP snooping enabled broadcast domain information
| URI | Description |
| <base_URI>/operational-state/igmp-snooping-state | Displays IGMP snooping enabled broadcast domain information |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example shows the complete cURL command and server response for the
igmp-snooping-state GET operation.
http://host:80/rest/operational-state/igmp-snooping-state
curl -H "Accept: application/vnd.operational-state.resource+xml" -H "Resource-Depth: 6" -u "lab:Tester**" http://10.20.229.40:80/rest/operational-state/igmp-snooping-state
<data xmlns="http://brocade.com/ns/rest" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state">
<igmp-snooping-state xmlns="urn:brocade.com:mgmt:brocade-mc-hms-operational" y:self="/rest/operational-state/igmp-snooping-state">
<multicast-ssm-mapping y:self="/rest/operational-state/igmp-snooping-state/multicast-ssm-mapping">
</multicast-ssm-mapping>
<igmp-statistics y:self="/rest/operational-state/igmp-snooping-state/igmp-statistics">
</igmp-statistics>
<debug-igmp y:self="/rest/operational-state/igmp-snooping-state/debug-igmp">
<enable-any>0</enable-any>
<error>0</error>
<packets>0</packets>
<query>0</query>
<v1-report>0</v1-report>
<direction>none</direction>
<phy-port-name>none</phy-port-name>
<io-port-name>none</io-port-name>
</debug-igmp>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488">
<vlan-id>3758098488</vlan-id>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3100">
<vlan-id>3100</vlan-id>
<multicast-router-ports>" ICL,"</multicast-router-ports>
<is-querier>0</is-querier>
<igmp-operation-mode>2</igmp-operation-mode>
<fast-leave>0</fast-leave>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<restrict-unknown-mcast>0</restrict-unknown-mcast>
<num-of-mcast-grps>1</num-of-mcast-grps>
</igmp-snooping-vlans>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3101">
<vlan-id>3101</vlan-id>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<num-of-mcast-grps>0</num-of-mcast-grps>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3102">
<vlan-id>3102</vlan-id>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3103">
<vlan-id>3103</vlan-id>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3104">
<vlan-id>3104</vlan-id>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3105">
<vlan-id>3105</vlan-id>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3106">
<vlan-id>3106</vlan-id>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3107">
<vlan-id>3107</vlan-id>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<igmp-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-vlans/3758098488/igmp-snooping-vlans/3108">
<vlan-id>3108</vlan-id>
<qmrt>10</qmrt>
<lmqi>1000</lmqi>
<qi>125</qi>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344">
<vlan-id>3758098344</vlan-id>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/4009">
<vlan-id>4009</vlan-id>
<interface-name>po40</interface-name>
<expiry-time>243</expiry-time>
</igmp-snooping-mrouters>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3250">
<vlan-id>3250</vlan-id>
<interface-name>ICL</interface-name>
<expiry-time>273</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/4042">
<vlan-id>4042</vlan-id>
<interface-name>po30</interface-name>
<expiry-time>258</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/4010">
<vlan-id>4010</vlan-id>
<interface-name>po41</interface-name>
<expiry-time>192</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3100">
<expiry-time>278</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3101">
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3102">
<expiry-time>279</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3103">
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3104">
<expiry-time>280</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3105">
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3106">
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3107">
<expiry-time>281</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3108">
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3109">
<vlan-id>3109</vlan-id>
<expiry-time>282</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3110">
<vlan-id>3110</vlan-id>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3111">
<vlan-id>3111</vlan-id>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3112">
<vlan-id>3112</vlan-id>
<expiry-time>283</expiry-time>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3113">
<vlan-id>3113</vlan-id>
<igmp-snooping-mrouters y:self="/rest/operational-state/igmp-snooping-state/igmp-snooping-mrouters/3758098344/igmp-snooping-mrouters/3114">
<vlan-id>3114</vlan-id>
<expiry-time>284</expiry-time>
<igmp-l3-interfaces y:self="/rest/operational-state/igmp-snooping-state/igmp-l3-interfaces/%22%22">
<interface-name>""</interface-name>
<igmp-l3-interfaces y:self="/rest/operational-state/igmp-snooping-state/igmp-l3-interfaces/%22%22/igmp-l3-interfaces/%22Ve 4009%22%2C172.31.12.37">
<interface-name>"Ve 4009"</interface-name>
<igmp-querier>172.31.12.37</igmp-querier>
<is-igmp-enabled>1</is-igmp-enabled>
<query-interval>125</query-interval>
<other-querier-interval>255</other-querier-interval>
<query-reponse-time>10</query-reponse-time>
<last-member-query-interval>1000</last-member-query-interval>
<immediate-leave>0</immediate-leave>
<is-igmp-querier-local>0</is-igmp-querier-local>
<igmp-version>2</igmp-version>
</igmp-l3-interfaces>
<igmp-l3-interfaces y:self="/rest/operational-state/igmp-snooping-state/igmp-l3-interfaces/%22%22/igmp-l3-interfaces/%22Ve 3250%22%2C172.19.40.1">
<interface-name>"Ve 3250"</interface-name>
<igmp-querier>172.19.40.1</igmp-querier>
<igmp-l3-interfaces y:self="/rest/operational-state/igmp-snooping-state/igmp-l3-interfaces/%22%22/igmp-l3-interfaces/%22Ve 4042%22%2C172.31.30.9">
<interface-name>"Ve 4042"</interface-name>
<igmp-querier>172.31.30.9</igmp-querier>
<igmp-groups y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22">
<group-addr>127.0.0.1</group-addr>
<igmp-groups y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22/igmp-groups/226.0.0.1%2Cvlan3100">
<group-addr>226.0.0.1</group-addr>
<interface-name>vlan3100</interface-name>
<uptime>03:07:27</uptime>
<expiry-time>00:03:09</expiry-time>
<last-reporter>172.20.201.40</last-reporter>
<filter-mode>1</filter-mode>
<member-ship>" po1,"</member-ship>
<oper-version>2</oper-version>
<igmpv3-sources y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22/igmp-groups/226.0.0.1%2Cvlan3100/igmpv3-sources/po1">
<interface-name>po1</interface-name>
</igmpv3-sources>
</igmp-groups>
<igmp-groups y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22/igmp-groups/226.0.0.1%2Cvlan3102">
<interface-name>vlan3102</interface-name>
<expiry-time>00:03:40</expiry-time>
<last-reporter>172.20.201.42</last-reporter>
<igmpv3-sources y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22/igmp-groups/226.0.0.1%2Cvlan3102/igmpv3-sources/po1">
</igmpv3-sources>
</igmp-groups>
<igmp-groups y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22/igmp-groups/226.0.0.1%2Cvlan3104">
<interface-name>vlan3104</interface-name>
<expiry-time>00:03:12</expiry-time>
<last-reporter>172.20.201.44</last-reporter>
<igmpv3-sources y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22/igmp-groups/226.0.0.1%2Cvlan3104/igmpv3-sources/po1">
</igmpv3-sources>
</igmp-groups>
<igmp-groups y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22/igmp-groups/226.0.0.1%2Cvlan3106">
<interface-name>vlan3106</interface-name>
<expiry-time>00:03:42</expiry-time>
<last-reporter>172.20.201.46</last-reporter>
<igmpv3-sources y:self="/rest/operational-state/igmp-snooping-state/igmp-groups/127.0.0.1%2C%22%22/igmp-groups/226.0.0.1%2Cvlan3106/igmpv3-sources/po1">
</igmpv3-sources>
</igmp-groups>
</igmp-groups>
<igmp-mct-groups y:self="/rest/operational-state/igmp-snooping-state/igmp-mct-groups/%22%22">
<client-id>""</client-id>
<igmp-entry y:self="/rest/operational-state/igmp-snooping-state/igmp-mct-groups/%22%22/igmp-entry/226.0.0.1%2CNil%2C%22Vlan 3100%22%2C%22Po 1%22">
<grp-addr>226.0.0.1</grp-addr>
<src-addr>Nil</src-addr>
<interface-name>"Vlan 3100"</interface-name>
<member-intf>"Po 1"</member-intf>
<member-type>CCEP</member-type>
<filter-mode>EXCLUDE</filter-mode>
<mcast-df>DF</mcast-df>
<peer-addr>Local</peer-addr>
</igmp-entry>
<igmp-entry y:self="/rest/operational-state/igmp-snooping-state/igmp-mct-groups/%22%22/igmp-entry/226.0.0.1%2CNil%2C%22Vlan 3101%22%2C%22Po 1%22">
<interface-name>"Vlan 3101"</interface-name>
<peer-addr>172.31.40.10</peer-addr>
</igmp-entry>
<igmp-entry y:self="/rest/operational-state/igmp-snooping-state/igmp-mct-groups/%22%22/igmp-entry/226.0.0.1%2CNil%2C%22Vlan 3102%22%2C%22Po 1%22">
<interface-name>"Vlan 3102"</interface-name>
</igmp-entry>
<igmp-entry y:self="/rest/operational-state/igmp-snooping-state/igmp-mct-groups/%22%22/igmp-entry/226.0.0.1%2CNil%2C%22Vlan 3103%22%2C%22Po 1%22">
<interface-name>"Vlan 3103"</interface-name>
</igmp-entry>
<igmp-entry y:self="/rest/operational-state/igmp-snooping-state/igmp-mct-groups/%22%22/igmp-entry/226.0.0.1%2CNil%2C%22Vlan 3104%22%2C%22Po 1%22">
<interface-name>"Vlan 3104"</interface-name>
</igmp-entry>
<igmp-entry y:self="/rest/operational-state/igmp-snooping-state/igmp-mct-groups/%22%22/igmp-entry/226.0.0.1%2CNil%2C%22Vlan 3105%22%2C%22Po 1%22">
<interface-name>"Vlan 3105"</interface-name>
</igmp-entry>
<igmp-entry y:self="/rest/operational-state/igmp-snooping-state/igmp-mct-groups/%22%22/igmp-entry/226.0.0.1%2CNil%2C%22Vlan 3106%22%2C%22Po 1%22">
<interface-name>"Vlan 3106"</interface-name>
</igmp-entry>
</igmp-mct-groups>
<pim-snp-groups y:self="/rest/operational-state/igmp-snooping-state/pim-snp-groups/3758098408%2C%22%22">
<vlan-id>3758098408</vlan-id>
<type>""</type>
<pim-snp-groups y:self="/rest/operational-state/igmp-snooping-state/pim-snp-groups/3758098408%2C%22%22/pim-snp-groups/226.0.0.1%2C3100">
</pim-snp-groups>
<pim-snp-groups y:self="/rest/operational-state/igmp-snooping-state/pim-snp-groups/3758098408%2C%22%22/pim-snp-groups/226.0.0.1%2C3102">
</pim-snp-groups>
<pim-snp-groups y:self="/rest/operational-state/igmp-snooping-state/pim-snp-groups/3758098408%2C%22%22/pim-snp-groups/226.0.0.1%2C3104">
</pim-snp-groups>
<pim-snp-groups y:self="/rest/operational-state/igmp-snooping-state/pim-snp-groups/3758098408%2C%22%22/pim-snp-groups/226.0.0.1%2C3106">
</pim-snp-groups>
<pim-snp-groups y:self="/rest/operational-state/igmp-snooping-state/pim-snp-groups/3758098408%2C%22%22/pim-snp-groups/226.0.0.1%2C3108">
</pim-snp-groups>
</pim-snp-groups>
<igmp-multicast-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-multicast-snooping-vlans/3758098296">
<vlan-id>3758098296</vlan-id>
<igmp-multicast-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-multicast-snooping-vlans/3758098296/igmp-multicast-snooping-vlans/4009">
<pim-sn-status>1</pim-sn-status>
<igmp-sn-status>1</igmp-sn-status>
</igmp-multicast-snooping-vlans>
<igmp-multicast-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-multicast-snooping-vlans/3758098296/igmp-multicast-snooping-vlans/3250">
<igmp-multicast-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-multicast-snooping-vlans/3758098296/igmp-multicast-snooping-vlans/4042">
<igmp-multicast-snooping-vlans y:self="/rest/operational-state/igmp-snooping-state/igmp-multicast-snooping-vlans/3758098296/igmp-multicast-snooping-vlans/4010">
</igmp-snooping-state>
</data>
| Release version | History |
| 18r.2.00 | This API call was introduced. |
