Retrieves the time stamp of the last configuration change on the system.
| URI | Description |
| <base_URI>/operations/get-last-config-update-time | Retrieves the time stamp of the last configuration change. |
Only POST operation is supported.
http://host:80/rest/operations/get-last-config-update-time
<get-last-config-update-time></get-last-config-update-time>
<output xmlns='urn:brocade.com:mgmt:brocade-vcs'> <last-config-update-time>1402481614</last-config-update-time> </output>
