protocol/spanning-tree/stp
Configures STP.
Resource URIs
URI Description
<base_URI>/config/running/protocol/spanning-tree/stp Configures STP.
GET URIs Description
<base_URI>/config/running/protocol/spanning-tree/stp Retrieves STP details.
<base_URI>/config/running/protocol/spanning-tree/stp/error-disable-timeout Retrieves error disable timeout.
<base_URI>/config/running/protocol/spanning-tree/stp/port-channel Retrieves port channel details.
POST URIs Payload Description
<base_URI>/config/running/protocol/spanning-tree/stp/error-disable-timeout <enable>(enumeration)</enable> Enables error disable timeout.
<base_URI>/config/running/protocol/spanning-tree/stp <shutdown>(enumeration)</shutdown> Shuts down.
PATCH URIs Payload Description
<base_URI>/config/running/protocol/spanning-tree/stp/description <description>(string)</description> Configures STP description.
<base_URI>/config/running/protocol/spanning-tree/stp/bridge-priority <bridge-priority>(unit32)</bridge-priority> Configures bridge priority.
<base_URI>/config/running/protocol/spanning-tree/stp/error-disable-timeout/enable <enable>(enumeration)</enable> Enables error disable timeout.
<base_URI>/config/running/protocol/spanning-tree/stp/error-disable-timeout/interval <interval>(unit32)</interval> Configures error disable timeout interval.
<base_URI>/config/running/protocol/spanning-tree/stp/forward-delay <forward-delay>(unit32)</forward-delay> Configures forward delay.
<base_URI>/config/running/protocol/spanning-tree/stp/max-age <max-age>(unit32)</max-age> Configures max age.
<base_URI>/config/running/protocol/spanning-tree/stp/port-channel/path-cost <path-cost>(enumeration)</path-cost> Configures path cost.
<base_URI>/config/running/protocol/spanning-tree/stp/shutdown <shutdown>(enumeration)</shutdown> Shuts down.
<base_URI>/config/running/protocol/spanning-tree/stp/hello-time <hello-time>(unit32)</hello-time> Configures hello time.
PUT URIs Payload Description
DELETE URIs
Parameters
description
Specifies description.
bridge-priority
Specifies bridge priority.
interval
Specifies the interval.
forward-delay
Specifies the forward delay.
max-age
Specifies max age.
path-cost
Specifies the path cost.
hello-time
Specifies the hello time.
transmit-holdcount
Specifies transmit hold count.
Usage Guidelines
GET, POST, PATCH, PUT, DELETE, HEAD, and OPTIONS operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/protocol/spanning-tree/stp
None
<stp xmlns="urn:brocade.com:mgmt:brocade-xstp" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/protocol/spanning-tree/stp">
  <hello-time>3</hello-time>
  <forward-delay>14</forward-delay>
  <max-age>19</max-age>
  <bridge-priority>4096</bridge-priority>
  <error-disable-timeout y:self="/rest/config/running/protocol/spanning-tree/stp/error-disable-timeout">
    <enable>true</enable>
    <interval>100</interval>
  </error-disable-timeout>
  <port-channel y:self="/rest/config/running/protocol/spanning-tree/stp/port-channel">
    <path-cost>custom</path-cost>
  </port-channel>
</stp>
URI
The following example uses the POST option to enable error disable timeout.
http://host:80/rest/config/running/protocol/spanning-tree/stp/error-disable-timeout
<enable>enable</enable>
None
URI
The following example uses the DELETE option to remove STP description.
http://host:80/rest/config/running/protocol/spanning-tree/stp/description
None
None
