Both success and error status are reported to the client by way of the HTTP Status-Line, which contains the HTTP status code. The application-specific error messages are similar to the CLI error messages.
Status-Line | Description |
100 Continue | POST is accepted, 201 should follow |
200 OK | Success with response body |
201 Created | POST to create a resource success |
202 Accepted | POST to create a resource accepted |
204 No Content | Success without response body |
400 Bad Request | Invalid request message |
403 Forbidden | Access to resource denied |
404 Not Found | Resource target or resource node not found |
405 Method Not Allowed | Method not allowed for target resource |
413 Request Entity Too Large | Too-big error |
414 Request-URI Too Large | Too-big error |
415 Unsupported Media | Not supported media type |
500 Internal Server Error | Operation failed. Note: In this case, the response body will contain the application's specific error message. |
501 Not Implemented | Unknown operation |
503 Service Unavailable | Recoverable server error |
