Configures, retrieves, and modifies MPLS Quality of Service (QoS).
| URI | Description |
| <base_URI>/config/running/qos-mpls | Configures MPLS Quality of Service (QoS). |
| GET URIs | Description |
| <base_URI>/config/running/qos-mpls | Retrieves and displays the information on all configured qos-mpls maps, and the details on applied maps. |
| <base_URI>/config/running/qos-mpls/map | Retrieves and displays the information on all configured qos-mpls maps. |
| <base_URI>/config/running/qos-mpls/map/exp-traffic-class/{exp-traffic-class-map-name} | Retrieves and displays the EXP-to-Traffic-Class map information for the map name specified in the URI. |
| <base_URI>/config/running/qos-mpls/map/exp-traffic-class/{exp-traffic-class-map-name}/exp/{exp-in-values} | Specify the map name and exp value in the URI to retrieve the configured traffic-class and drop-precedence value. |
| <base_URI>/config/running/qos-mpls/map/exp-traffic-class/{exp-traffic-class-map-name}/exp/{exp-in-values}/to | Specify the map name and exp value in the URI to retrieve the configured traffic-class and drop-precedence value. |
| <base_URI>/config/running/qos-mpls/map/traffic-class-exp/{traffic-class-exp-map-name} | Retrieves and displays Traffic-Class-to-EXP map information for the map name specified in the URI. |
| <base_URI>/config/running/qos-mpls/map/traffic-class-exp/{traffic-class-exp-map-name}/traffic-class/{priority-in-values},{drop-precedence} | Specify the map name, traffic-class and drop-precedence values in the URI to retrieve the configured exp value. |
| <base_URI>/config/running/qos-mpls/map/dscp-exp/{dscp-exp-map-name} | Retrieves and displays the DSCP-to-EXP map information for the map name specified in the URI. |
| <base_URI>/config/running/qos-mpls/map/dscp-exp/{dscp-exp-map-name}/dscp/{dscp-in-values} | Specify the map name and DSCP value in the URI to retrieve the configured exp value. |
| <base_URI>/config/running/qos-mpls/map/dscp-exp/{dscp-exp-map-name}/dscp/{dscp-in-values}/to | Specify the map name and DSCP value in the URI to retrieve the configured exp value. |
| <base_URI>/config/running/qos-mpls/map/exp-dscp/{exp-dscp-map-name} | Retrieves and displays the EXP-to-DSCP map information for the map name specified in the URI. |
| <base_URI>/config/running/qos-mpls/map/exp-dscp/{exp-dscp-map-name}/exp/{exp-in-values} | Specify the map name and exp value in the URI to retrieve the configured dscp value. |
| <base_URI>/config/running/qos-mpls/map/exp-dscp/{exp-dscp-map-name}/exp/{exp-in-values}/to | Specify the map name and exp value in the URI to retrieve the configured dscp value. |
| <base_URI>/config/running/qos-mpls/map-apply | Retrieves information about the qos-mpls map applied on the device. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-traffic-class | Retrieves information about the qos-mpls map of type exp-traffic-class applied on the device. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-traffic-class/All | If the qos-mpls map of type exp-traffic-class is applied, the value of the field "All" will be always true, which indicates that the map is globally applied. If the map is not applied, a "Not found" error will be returned. |
| <base_URI>/config/running/qos-mpls/map-apply/traffic-class-exp | Retrieves information about the qos-mpls map of type traffic-class-exp applied on the device. |
| <base_URI>/config/running/qos-mpls/map-apply/traffic-class-exp/All | If the qos-mpls map of type traffic-class-exp is applied. The value of the field "All" will be always true, which indicates that the map is globally applied. If the map is not applied, a "Not found" error will be returned. |
| <base_URI>/config/running/qos-mpls/map-apply/dscp-exp | Retrieves information about the qos-mpls map of type dscp-exp applied on the device. |
| <base_URI>/config/running/qos-mpls/map-apply/dscp-exp/All | If the qos-mpls map of type dscp-exp is applied, the value of the field "All" will be always true, which indicates that the map is globally applied. If the map is not applied, a "Not found" error will be returned. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-dscp | Retrieves information about the qos-mpls map of type exp-dscp applied on the device. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-dscp/All | If the qos-mpls map of type exp-dscp is applied, the value of the field "All" will be always true, which indicates that the map is globally applied. If the map is not applied, a "Not found" error will be returned. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/qos-mpls/map | <exp-traffic-class><exp-traffic-class-map-name>{map-name-type}</exp-traffic-class-map-name></exp-traffic-class> | Configures EXP traffic class |
| <base_URI>/config/running/qos-mpls/map/exp-traffic-class/{exp-traffic-class-map-name} | <exp><exp-in-values>{uint32}</exp-in-values><to><traffic-class>{uint32}</traffic-class><drop-precedence>{uint32}</drop-precedence></to></exp> | Maps EXP values to Traffic Class Value. |
| <base_URI>/config/running/qos-mpls/map | <traffic-class-exp><traffic-class-exp-map-name>{map-name-type}</traffic-class-exp-map-name></traffic-class-exp> | Configures Traffic class EXP |
| <base_URI>/config/running/qos-mpls/map/traffic-class-exp/{traffic-class-exp-map-name} | <traffic-class><priority-in-values>{uint32}</priority-in-values><drop-precedence>{uint32}</drop-precedence><to>{enumeration}</to><exp>{uint32}</exp></traffic-class> | Maps Traffic class value to EXP value |
| <base_URI>/config/running/qos-mpls/map | <dscp-exp><dscp-exp-map-name>{map-name-type}</dscp-exp-map-name></dscp-exp> | Configures DSCP EXP. |
| <base_URI>/config/running/qos-mpls/map/dscp-exp/{dscp-exp-map-name} | <dscp><dscp-in-values>{uint32}</dscp-in-values><to><exp>{uint32}</exp></to></dscp> | Maps DSCP value to EXP value. |
| <base_URI>/config/running/qos-mpls/map | <exp-dscp><exp-dscp-map-name>{map-name-type}</exp-dscp-map-name></exp-dscp> | Configures EXP DSCP. |
| <base_URI>/config/running/qos-mpls/map/exp-dscp/{exp-dscp-map-name} | <exp><exp-in-values>{uint32}</exp-in-values><to><dscp>{uint32}</dscp></to></exp> | Maps EXP value to DSCP value |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/qos-mpls/map/exp-traffic-class/{exp-traffic-class-map-name}/exp/{exp-in-values}/to | <to><traffic-class>{uint32}</traffic-class><drop-precedence>{uint32}</drop-precedence></to> | Updates the configured traffic-class and drop-precedence value in the exp-traffic-Class map specified. |
| <base_URI>/config/running/qos-mpls/map/traffic-class-exp/{traffic-class-exp-map-name}/traffic-class/{priority-in-values},{drop-precedence}/to | <to><exp>{uint32}</exp></to> | Updates the configured exp value in traffic-class-exp map specified. |
| <base_URI>/config/running/qos-mpls/map/dscp-exp/{dscp-exp-map-name}/dscp/{dscp-in-values}/to | <to><exp>{uint32}</exp></to> | Updates the configured exp value in the dscp-exp map specified. |
| <base_URI>/config/running/qos-mpls/map/exp-dscp/{exp-dscp-map-name}/exp/{exp-in-values}/to | <to><dscp>{uint32}</dscp></to> | Updates the configured dscp value in the exp-dscp map specified. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/qos-mpls/map-apply/traffic-class-exp | <traffic-class-exp><map-name-cmd2>{map-name-type}</map-name-cmd2><All>{enumeration}</All></traffic-class-exp> | Applies the qos-mpls map name provided in payload of type traffic-class-exp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/traffic-class-exp | <traffic-class-exp><all-zero-map>{enumeration}</all-zero-map><All>{enumeration}</All></traffic-class-exp> | Applies the qos-mpls all-zero-map of type traffic-class-exp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/traffic-class-exp | <traffic-class-exp><default-map>{enumeration}</default-map><All>{enumeration}</All></traffic-class-exp> | Applies the qos-mpls default-map of type traffic-class-exp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/dscp-exp | <dscp-exp><map-name-cmd3>{map-name-type}</map-name-cmd3><All>{enumeration}</All></dscp-exp> | Applies the qos-mpls map name provided in payload of type dscp-exp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/dscp-exp | <dscp-exp><all-zero-map>{enumeration}</all-zero-map><All>{enumeration}</All></dscp-exp> | Applies the qos-mpls all-zero-map of type traffic-class-exp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/dscp-exp | <dscp-exp><default-map>{enumeration}</default-map><All>{enumeration}</All></dscp-exp> | Applies the qos-mpls default-map of type traffic-class-exp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-dscp | <exp-dscp><map-name-cmd4>{map-name-type}</map-name-cmd4><All>{enumeration}</All></exp-dscp> | Applies the qos-mpls map name provided in payload of type exp-dscp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-dscp | <exp-dscp><all-zero-map>{enumeration}</all-zero-map><All>{enumeration}</All></exp-dscp> | Applies the qos-mpls all-zero-map of type exp-dscp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-dscp | <exp-dscp><default-map>{enumeration}</default-map><All>{enumeration}</All></exp-dscp> | Applies the qos-mpls default-map of type exp-dscp globally. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-traffic-class | <exp-traffic-class><map-name-cmd1>{map-name-type}</map-name-cmd1><All>true</All></exp-traffic-class> | Applies the qos-mpls map name provided in payload of type exp-traffic-class globally. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-traffic-class | <exp-traffic-class><all-zero-map>true</all-zero-map><All>true</All></exp-traffic-class> | Applies the qos-mpls all-zero-map of type exp-traffic-class globally. |
| <base_URI>/config/running/qos-mpls/map-apply/exp-traffic-class | <exp-traffic-class><default-map>true</default-map><All>true</All></exp-traffic-class> | Applies the qos-mpls default-map of type exp-traffic-class globally. |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/qos-mpls
None
<qos-mpls xmlns="urn:brocade.com:mgmt:brocade-qos-mpls" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/qos-mpls">
<map y:self="/rest/config/running/qos-mpls/map">
<exp-traffic-class y:self="/rest/config/running/qos-mpls/map/exp-traffic-class/e2tc1">
<exp-traffic-class-map-name>e2tc1</exp-traffic-class-map-name>
<exp y:self="/rest/config/running/qos-mpls/map/exp-traffic-class/e2tc1/exp/3">
<exp-in-values>3</exp-in-values>
<to y:self="/rest/config/running/qos-mpls/map/exp-traffic-class/e2tc1/exp/3/to">
<traffic-class>5</traffic-class>
<drop-precedence>1</drop-precedence>
</to>
</exp>
<traffic-class-exp y:self="/rest/config/running/qos-mpls/map/traffic-class-exp/tc2e1">
<traffic-class-exp-map-name>tc2e1</traffic-class-exp-map-name>
<traffic-class y:self="/rest/config/running/qos-mpls/map/traffic-class-exp/tc2e1/traffic-class/5%2C0">
<priority-in-values>5</priority-in-values>
<drop-precedence>0</drop-precedence>
<to y:self="/rest/config/running/qos-mpls/map/traffic-class-exp/tc2e1/traffic-class/5%2C0/to">
<exp>7</exp>
</to>
</traffic-class>
<traffic-class y:self="/rest/config/running/qos-mpls/map/traffic-class-exp/tc2e1/traffic-class/5%2C2">
<drop-precedence>2</drop-precedence>
<to y:self="/rest/config/running/qos-mpls/map/traffic-class-exp/tc2e1/traffic-class/5%2C2/to">
<exp>7</exp>
</to>
</traffic-class>
<dscp-exp y:self="/rest/config/running/qos-mpls/map/dscp-exp/d2e1">
<dscp-exp-map-name>d2e1</dscp-exp-map-name>
<dscp y:self="/rest/config/running/qos-mpls/map/dscp-exp/d2e1/dscp/1">
<dscp-in-values>1</dscp-in-values>
<to y:self="/rest/config/running/qos-mpls/map/dscp-exp/d2e1/dscp/1/to">
<exp>4</exp>
</to>
</dscp>
</dscp-exp>
<exp-dscp y:self="/rest/config/running/qos-mpls/map/exp-dscp/e2d1">
<exp-dscp-map-name>e2d1</exp-dscp-map-name>
<exp y:self="/rest/config/running/qos-mpls/map/exp-dscp/e2d1/exp/5">
<exp-in-values>5</exp-in-values>
<to y:self="/rest/config/running/qos-mpls/map/exp-dscp/e2d1/exp/5/to">
<dscp>34</dscp>
</to>
</exp>
</exp-dscp>
</map>
<map-apply xmlns="urn:brocade.com:mgmt:brocade-apply-qos-mpls" y:self="/rest/config/running/qos-mpls/map-apply">
<exp-traffic-class y:self="/rest/config/running/qos-mpls/map-apply/exp-traffic-class">
<map-name-cmd1>e2tc1</map-name-cmd1>
<All>true</All>
<traffic-class-exp y:self="/rest/config/running/qos-mpls/map-apply/traffic-class-exp">
<map-name-cmd2>tc2e1</map-name-cmd2>
<All>true</All>
<dscp-exp y:self="/rest/config/running/qos-mpls/map-apply/dscp-exp">
<map-name-cmd3>d2e1</map-name-cmd3>
<All>true</All>
</dscp-exp>
<exp-dscp y:self="/rest/config/running/qos-mpls/map-apply/exp-dscp">
<map-name-cmd4>e2d1</map-name-cmd4>
<All>true</All>
</exp-dscp>
</map-apply>
</qos-mpls>
The following example uses the POST option to configure EXP traffic class.
http://host:80/rest/config/running/qos-mpls/map
<exp-traffic-class><exp-traffic-class-map-name>plsmap</exp-traffic-class-map-name></exp-traffic-class>
None
The following example uses the DELETE option to remove dot1x.
http://host:80/rest/config/running/qos-mpls/map/exp-traffic-class/plsmap
None
None
