Copies configuration data to or from the system.
| URI | Description |
| <base_URI>/operations/bna-config-cmd | Copy configuration data to or from the system. |
Only POST operation is supported.
http://host:80/rest/operations/bna-config-cmd
<bna-config-cmd> <src>running-config</src> <dest>startup-config</dest> </bna-config-cmd>
<output xmlns='urn:brocade.com:mgmt:brocade-ras'> <session-id>0</session-id> <status>in-progress</status> </output>
