Use the area-tracking command to enable or disable Location Area Tracking. When area-tracking is enabled, the Location Engine tracks client locations within pre-defined map areas. When the clients change map areas, a notification is sent. If area-tracking is disabled, then Area Roaming is used instead. For more information on Area Roaming, see mac-roam.
The area-tracking command is accessible from the location context.
| enable | disable | Enables or disables area-tracking by the location engine on this controller. |
The following example enables area-tracking:
EWC.extremenetworks.com:location# area-tracking enable
Print
this page
Email this topic
Feedback
