Use the show app command to show the application visibility group configuration. The group names are pre-defined standard Extreme Application Analytics™ signature groups. The group names are case-sensitive.
To see a list of pre-defined group names, see show app group.
| apptype | Specifies the application type. Possible values:
| group group_name | Displays applications within the specified group. |
We recommend using the group parameter. Using the apptype all parameter without the group can result in over 2000 applications. Group names are case sensitive. You can run this command from the root or from the vnsmode:custom-app context.
EWC.extremenetworks.com show app apptype built-in group p2p
The following example shows all applications from group p2p regardless of type.
EWC.extremenetworks.com show app group p2p
Print
                        this page
Email this topic
Feedback
