Use the concurrent-number command to configure the maximum number of channels on which a Guardian AP can concurrently launch countermeasures. The concurrent-number command is accessible from the mitigator:gsprof:<named guardian scan profile> context of the CLI.
After you run the concurrent-number command, run the apply command to implement the change.
| 1-4 | The maximum number of channels on which countermeasures can be concurrently launched. Valid values are not less than one, or greater than 4. |
This command can be applied on any AP, except AP3705. An AP can concurrently launch countermeasures on all channels it is scanning. As more countermeasures are applied and the number of channels to which they are applied increases, the frequency of countermeasures being applied will decrease.
The following example enables countermeasures on two concurrent channels:
EWC.extremenetworks.com:mitigator:gsprof:scp_name# concurrent-number 2 EWC.extremenetworks.com:mitigator:gsprof:scp_name# apply
Print
                        this page
Email this topic
Feedback
