Use the help command to display available commands in a context, or obtain usage information for a specified command.
| command | Specifies the command for which you need usage information. |
The following example displays the available commands in the ap:defaults context:
EWC.extremenetworks.com:ap:defaults# help Available commands are: 3935FCC Modify 3935FCC ap defaults settings ap37xx Modify ap37xx and W78xC ap defaults settings ap3801 Modify ap3801 ap defaults settings ap38xx Modify ap38xx ap defaults settings apply Commit AP default changes. assign Modify AP default VNS assignment settings end exit learnac Enable/disable learn on the AP. logout no Clear the command setting show Display settings
The following example displays the usage information for the serial command:
EWC.extremenetworks.com:ap:# help serial
Create a new AP entry
Usage: serial <ap serial number> <name> <hardware type> <ap_role> [<description>]
Usage: no serial <serial#>
<hardware type> is one of:
  AP3705i (Wireless AP3705i Internal)
  AP3710e (Wireless AP3710e External)
  AP3710i (Wireless AP3710i Internal)
  AP3715e (Wireless AP3715e External)
  AP3715i (Wireless AP3715i Internal)
  AP3715i-1 (Wireless AP3715i-1 Internal)
  AP3765e (Wireless AP3765e External)
  AP3765i (Wireless AP3765i Internal)
  AP3767e (Wireless AP3767e External)
  AP3801i (Wireless AP3801i Internal)
  AP3805e (Wireless AP3805e External)
  AP3805i (Wireless AP3805i Internal)
  AP3825e (Wireless AP3825e External)
  AP3825i (Wireless AP3825i Internal)
  AP3865e (Wireless AP3865e External)
  AP3935e-FCC (Wireless AP3935e-FCC External)
  AP3935i-FCC (Wireless AP3935i-FCC Internal)
