Use the apcustom command to enable AP custom filters. The apcustom command is accessible from the role:<named-role> context.
| enable | disable | Provides for the enabling or disabling of AP custom filters for this role:<named-role> context. |
Enabling AP custom filters provides for the ability to access the role:<named-role>:apfilters context using the apfilters command. The apfilters command allows for the configuration of additional filters for the APs.
Filtering on the AP must be enabled using the ulfilterap enable command for the apcustom command to be visible in the CLI.
The following example enables AP custom filters for the role:p1:apfilters context:
EWC.extremenetworks.com:role:p1# ulfilterap enable EWC.extremenetworks.com:role:p1# apcustom enable EWC.extremenetworks.com:role:p1#
Print
                        this page
Email this topic
Feedback
