Use the secmode command to set the Security Mode to allow only approved Agents to connect to the manager, or allow all agents to connect.
| approved | Allows only approved agents to connect to the manager |
| none | Allows all agents to connect to the manager |
The following example configures the security mode to have no restrictions, allowing all agents to connect to the manager:
EWC.extremenetworks.com:mobility# secmode none
Print
this page
Email this topic
Feedback
