show
      The show command allows you to display configuration information, including
            lbs-status, for a specific AP or all APs of a specific type.
The show command is accessible from the following contexts:
            - ap:<serial> — Use the show command in this context to display
               configuration information for a specific AP. See show.
            - ap:defaults:11n
               configuration information for all 38xx APs. See show.
