Use the maxsessionlifetime command, within context wlan:<WLAN-service-name>:auth:captiveportal, to configure the maximum session lifetime for the guest portal access account, in hours.
After you run the maxsessionlifetime command, run the apply command to implement the changes.
| hours | Specifies the maximum number of hours for the session time of the guestportal access account |
The guestportal authentication mode must be set for this command to be available. For more information, see mode.
The following example sets the maximum session lifetime for the guest portal account to one hour:
EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# maxsessionlifetime 1 EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# apply EWC.extremenetworks.com:wlans:CNL-CP:auth:captiveportal# show maxsessionlifetime maxsessionlifetime 1
Print
                        this page
Email this topic
Feedback
