Use the push command to enable or disable the push operation on this controller. This command is available from the location:publish context.
| enable | disable | Enables or disables the push operation on this controller. |
The following example enables the push operation on this controller:
EWC.extremenetworks.com:location:publish# push enable
Print
                        this page
Email this topic
Feedback
