Use the show system_state command to display the Wireless Appliance's system information.
| process | Displays the current CPU and memory usage of system processes. |
| cpu | Displays the amount of CPU usage. |
| memory | Displays the amount of memory being used on the system. |
| disk | Displays the hard-disk usage by folder. |
| mgmt | Displays the system management settings. |
| uptime | Displays the amount of time the system has been running continuously. |
| info | Displays the information on various processes run by the system. |
| manufacturing | Displays hardware information about the controller. |
EWC.extremenetworks.com# show system_state process PID Process Name State % CPU % Mem 1123 VN Manager S 0.0 0.9 8010 NSM Server S 0.0 0.6 16527 Config Manager S 0.0 1.6 1425 CLI S 0.0 3.5 - OSPF Server inactive - - - Remote INS inactive - - 15891 Langley S 0.0 0.5 1111 RU Manager S 0.0 0.9 15893 SNMP Agent S 0.0 0.5 - RF Data Collector inactive - - 23758 Radius Client S 0.0 0.5 960 Stats Server S 0.0 0.6 16566 Security Manager S 0.0 0.9 656 Event Server S 0.0 1.4 548 Startup Manager S 0.0 0.5 1131 RU Session Manager S 0.0 0.5 974 Host Services Manager S 0.0 2.3 1117 Radius Accounting S 0.0 0.4 - DHCP inactive - - 990 Test Client S 0.0 0.4 1129 LLC Handler S 0.0 0.6
EWC.extremenetworks.com# show system_state cpu CPU states: 1.5% user, 1.5% system, 0.0% nice, 6.8% idle
EWC.extremenetworks.com# show system_state memory Mem: 247372K av, 235516K used, 11856K free, 0K shrd, 67528K buff Swap: 1028120K av, 6368K used, 1021752K free 85756K cached
EWC.extremenetworks.com# show system_state disk Partition Total Space Used Available Use % root 27193624 381960 25992592 2% home 2040016 32840 1986696 2% cdr 2032048 32812 1978756 2% logs 1528032 33180 1479512 3% reports 1522032 32812 1473880 3% trace 1531008 32812 1482856 3% tmp 131072 32 131040 1%
EWC.extremenetworks.com# show system_state mgmt Software version: 9.xx Software build: 09.xx.0x.0xxx Product Name: C25 Hostname: EWC Domain: extremenetworks.com IP Address: 192.168.33.333 Subnet Mask: 255.255.255.0 Mgmt Gateway: 192.168.22.2 Static IPv6 Address: fd66:2280:2669:ffff::102 64 Static IPv6 Gateway: fd66:2280:2669:ffff::105 Dynamic IPv6 Address: 1: fd66:2280:2669:ffff:021b:21ff:feb0:899a 64 2: fd66:2280:2669:0000:021b:21ff:feb0:899a 64 3: fe80:0000:0000:0000:021b:21ff:feb0:899a 64 4: fe80:0000:0000:0000:0230:48ff:fe77:a94a (gw) Primary DNS: fd66:2280:2669::f Secondary DNS: 192.168.33.332 Time Zone: America/Montreal Country: CA
EWC.extremenetworks.com# show system_state uptime System uptime: 6 days, 1:49
