Use the multicast command to set the location-based server multicast address. The multicast command is accessible from the lbs context of the CLI.
| 0x:0x:0x:0x:0x:0x | Specifies the multicast address of the location-based server, in hexadecimal format. |
This command is visible only if a location-based service has been enabled via the service command.
The default multicast address is 00:00:00:00:00:00
The following example sets the multicast address of the Ekahau server to 01:18:8e:00:00:00:
EWC.extremenetworks.com:lbs# service ekahau EWC.extremenetworks.com:lbs# multicast 01:18:8e:00:00:00
Print
                        this page
Email this topic
Feedback
