Use the show export command to display a list of available export files, or the details about the specific file. During the export process, the text files, containing the controller's configuration, cdrs, logs, audit are zipped for which the files display .zip extension. The configuration text files are displayed with .cli extension.
| filename | Specifies the file name of an export file on the list. If the export file is located on a flash drive, the string “(flash)” must be suffixed to the end of the specified file name. |
| number | Specifies the index number of an export file on the list. |
The following example displays all the exported text files that contain controller‘s configuration, cdrs, logs, audit, or all of them:
EWC.extremenetworks.com# show export 1: test-lab6.04102014.174541.zip 2: test-lab6.04102014.174554.zip 3: test-lab6.04102014.174608.zip 4: test-lab6.04102014.174619.zip
The following example displays the details associated with the export file stored on flash:
EWC.extremenetworks.com# show export last_bak.zip(flash)
Comment="Time for another backup"
Backup type="all"
Backup creation date="Tue Jan 14 17:29:49 2014"
Backup/Export saved from software version="C5210-09.01.01.0186"
Print
                        this page
Email this topic
Feedback
