Use the exit command to return to the previous context, or to exit the shell if you are in the base context.
None
The following example exits a context and moves up one level to the previous context.
EWC.extremenetworks.com:policy:p1# exit EWC.extremenetworks.com:policy#
The following example exits the shell from the base context.
EWC.extremenetworks.com# exit
Print
                        this page
Email this topic
Feedback
