Use the duration command to configure maintenance cycle duration in hours.
After you run the duration command, run the apply command to implement the change.
| 1-6 | Number of hours for the maintenance cycle. |
Use the duration command to configure the duration of the maintenance cycle.
The following example specifies the duration of the maintenance cycle:
EWC.extremenetworks.com:maintain_cycle# duration 1
Print
                        this page
Email this topic
Feedback
