Use the ntp command to use the Network Time Protocol (NTP). Use the no form of the command to disable it. If you want to use the external NTP Server, configure the NTP Server‘s IP address by running the ntpip command. For more information, see ntpip.
| 2 | Specifies to use the external NTP Server to synchronize the network time |
| 3 | Specifies to use the internal NTP Server to synchronize the network time |
The following example specifies to use the internal NTP Server to synchronize the network time:
EWC.extremenetworks.com:time# ntp 3
Print
                        this page
Email this topic
Feedback
