Use the gateway command to specify the gateway IP address. The gateway command is available from the topology:<named-topology>:l3 context of the CLI for the Admin topology.
| A.B.C.D | Specifies the gateway IP address. |
| none | Clears the gateway IP address. |
The following example clears the gateway IP address:
EWC.extremenetworks.com:topology:Admin:l3:# gateway none
Print
                        this page
Email this topic
Feedback
