Use the show flash command to display whether the flash device is mounted or not.
| status | Displays whether the flash device is mounted or not. |
| sysinfo | Displays the memory usage information of the flash device. |
| list | Displays all the files on the flash device. |
The show flash command is applicable only to the Wireless Appliances that support flash devices.
The following example displays that the flash device is mounted:
EWC.extremenetworks.com# show flash status flash mounted
The following example displays the following memory usage information of the flash device:
EWC.extremenetworks.com# show flash sysinfo Size Used Available Use % 3.9G 32k 3.9G 1%
The following example displays the list of files that are saved on the flash device:
EWC.extremenetworks.com# show flash list AC-MV-gxs-V5R3.10007.0-1.tar gxs-V5R3.10007.0-1-rescue.tgz
Print
                        this page
Email this topic
Feedback
