Use the tz command to set the time zone for the Wireless Appliance. The tz command is accessible from within the root context.
The Wireless Appliance reboots when the time zone is changed.| continent continent | seqid | Indicates the continent. Valid values are continent name or database sequence ID. Use the show-continents command to view a list of continents. |
| region region | seqid | Specifies the region. Valid values are region name or database sequence ID. Use the show-regions command to view a list of regions. |
Use the respective show commands to view a list of continents and regions in the database. Configure the time zone using the continent and region name or database sequence ID.
After running tz, run the apply command.EWC.extremenetworks.com:time# show-continents
EWC.extremenetworks.com:time# show-regions America
The following example sets the controller time zone using the available continent and region information. Set time zone using continent and region name:
EWC.extremenetworks.com:time# tz continent America region Lima
Or, set time zone using continent and region sequence ID:
EWC.extremenetworks.com:time# tz continent 2 region 86
