Use the wpa-v2-key-mgmt command to configure WPA v2 key management options. The wpa-v2-key-mgmt command is accessible from the wlan:<WLAN-service-name>:priv context of the CLI.
After you run the wpa-v2-key-mgmt command, run the apply command to implement the name change.
| none | both | pre-auth | okc | Specifies WPA v2 key management from these options, respectively: none, both pre-authorization and Opportunistic Key Caching (OKC), pre-authorization only, or OKC only |
The wpa-v2-key-mgmt command is available when the privacy mode is set to wpa. This command is not available when the privacy mode is set to wpa-psk. For more information, see mode.
The following example sets WPA v2 key management to both pre-authorization and Opportunistic Key Caching (OKC):
EWC.extremenetworks.com:wlans:test:priv# wpa-v2-key-mgmt both EWC.extremenetworks.com:wlans:test:priv# apply EWC.extremenetworks.com:wlans:test:priv# show wpa-v2-key-mgmt Key Management Options: both
Print
                        this page
Email this topic
Feedback
