Network elements on the Wireless Appliance can be synchronized to a universal clock in one of two ways:
The commands described in this section are used to select and configure these options, and are located in the time context of the CLI.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
After you run any of the time commands, run the apply command to implement the changes.
The following commands are available in the time context:
Print
                        this page
Email this topic
Feedback
