lbs-status
      The lbs-status command allows you to enable or disable the collection of
            AeroScout/Ekahau tags on a specific AP or all APs of a given type.
The lbs-status command is accessible from the following contexts:
            - ap:<serial> — Use the lbs-status command in this context to
               enable or disable the collection of AeroScout/Ekahau tags on a specific AP. See location.
            - ap:defaults:11n
               enable or disable the collection of AeroScout/Ekahau tags on all 38xx APs. See lbs-status.
