The traffic_capture command moves you to the traffic_capture context, which contains the commands to manage the TCPDump. The traffic_capture command is accessible from the root context of the CLI.
All CLI commands cache changes. For this reason, sometimes when you make a change in a particular context, the change may not be visible immediately. If this happens, you must exit and re-enter the context in order to ensure that the database is synchronized with the latest change.
The following commands are available in the traffic_capture context:
Print
this page
Email this topic
Feedback
