Use the secure-tunnel-lifetime command to enable or configure the lifetime (the number of hours the tunnel remains enabled) of this tunnel. The secure-tunnel-lifetime command is accessible from the ap:<serial> and all ap:defaults contexts of the CLI.
| hours | Specifies the number of hours the tunnel will remain enabled. |
The secure-tunnel command must be enabled before the secure-tunnel-lifetime command can be run. The default is 0 hours, indicating the tunnel remains enabled until it is manually disabled. Valid entries are 0, or any number between 24-3600. When this value expires, the tunnel becomes disabled. Use the secure-tunnel disable command to terminate a tunnel.
The following example enables a secure tunnel for 24 hours:
EWC.extremenetworks.com:ap:defaults:ap37xx# secure-tunnel-lifetime 24
Print
                        this page
Email this topic
Feedback
