Use the ch command to set a fixed channel for this radio. The ch command is accessible from the ap:<serial>: radio contexts of the CLI.
| channel number | Specifies the number of the channel this radio uses. Possible channel ranges are:
Actual channels available depend on AP type, controller license, country, antenna settings, AP environment, and radio mode. It is advisable to set the channel to Auto and allow the controller to ensure the best overall wireless coverage for the environment. |
The following example sets the channel to 40 on Radio 1:
EWC.extremenetworks.com:ap:<serial>:radio1# ch 40
The following example checks available channels and then sets the channel to Auto on Radio 1:
EWC.extremenetworks.com:ap:1313254259510000:radio1# ch Usage:ch (Auto|36|40|44|48|52|56|60|64|100|104|108|112|149|153|157|161) Auto 36: ([5180],5200,5220,5240):13.5dBm 40: (5180,[5200],5220,5240):13.5dBm 44: (5180,5200,[5220],5240):13.5dBm 48: (5180,5200,5220,[5240]):13.5dBm 52: ([5260],5280,5300,5320):15.5dBm 56: (5260,[5280],5300,5320):15.5dBm 60: (5260,5280,[5300],5320):15.5dBm 64: (5260,5280,5300,[5320]):15.5dBm 100: ([5500],5520,5540,5560):15.5dBm 104: (5500,[5520],5540,5560):15.5dBm 108: (5500,5520,[5540],5560):15.5dBm 112: (5500,5520,5540,[5560]):15.5dBm 149: ([5745],5765,5785,5805):21.5dBm 153: (5745,[5765],5785,5805):21.5dBm 157: (5745,5765,[5785],5805):21.5dBm 161: (5745,5765,5785,[5805]):21.5dBm EWC.extremenetworks.com:ap:<serial>:radio1# ch Auto
Print
this page
Email this topic
Feedback
